| Message |
Yes, the sensor is there and we closed the hood to ensure that it wasn't part of the problem. The "car alarm" you're referring to is, I believe, the anti-theft ECU based on the location you provided - I did try that - no change. There's a horn relay attached to the top of the anti-theft ECU - I did a couple of diagnoses on the pins, which seemed to be fine, but I did *not* test the relay itself (ran out of time). Thanks for your response.. appreciate any other leads or suggestions! -jb
